11-16-2016 | #11 |
Re: '91 #473 Tuning
Moate's APU 1.. wideband hooked up to same analog channel 1.
Sent from my XT1585 using ZR-1 Net Registry mobile app |
11-16-2016 | #12 | |
Re: '91 #473 Tuning
11-16-2016 | #13 |
Re: '91 #473 Tuning
Ok, never used APU. Will u be using TPRT as the datalogger then?
11-17-2016 | #14 |
Re: '91 #473 Tuning
Yes.. should have it hooked up tonight to see how it goes. Need to check the *adx data stream definition and modify to monitor what I want to see.. more info as I make the transition to OBDI..
11-19-2016 | #15 |
Re: '91 #473 Tuning
OK, hit a snag. The ADX I have is for LT1/L98.
Jeff, do you have an ADX that will communicate with my '91 LT-5? ECM has BCC of AXFK. Using $AFA mask for my BIN definition. Thanks gents! Steve |
11-19-2016 | #16 |
Re: '91 #473 Tuning
U can find the .ads for the $F0 mask and convert it to an adx. Tunerpro has a utility for that.
I was able to use the .adx for $8EA on my 92, so perhaps the $F0 could work for the 92 http://www.tunerpro.net/download/datastreams/GM/F0.ads
11-19-2016 | #17 |
Re: '91 #473 Tuning
mine I know will work
it is attached
1990 Corvette ZR-1 #1051 Watson Headers (2" Primary) - 3" Magnaflow Bullet cats - Borla Catback Late Model IH - Plenum Coilovers - 4.10s Custom Interior NCM Lifetime Member #978 |
11-20-2016 | #18 |
Re: '91 #473 Tuning
Jeff,
Thanks so much.. I uploaded the ADX and tried to establish communication through the APU 1 via the ALDL cable. No go.. I'll get back in touch with Dave at Moate's to see where I'm going wrong. Continues to show DA Not Connected. TunerPro RT5 obviously looking for something I'm not providing. Once I can find out what I'm doing wrong, I'll post so others can see my error(s). Best Regards, Steve |
11-20-2016 | #19 |
Re: '91 #473 Tuning
Steve,
Are u checking to see which port is opened when u connect. Sometimes TPRT needs the device connected thru port 2,3, or 4. Check Device Manager.
11-20-2016 | #20 |
Re: '91 #473 Tuning
Checking.. I think it's com2.. will verify. I know it must be something simple!
