02-27-2014 | #11 | |
Re: Radiator Hose Clamp Markings
Sure do appreciate the assist.
02-27-2014 | #12 |
All from 90 taken off at 20k miles
1990, X-over Pipe to Rad Inlet Hose, "T" X-over end had a screw clamp from Germany Had tag on it 1990, X-over Pipe to Bypass Hose, Gray clamp with hole 1990, Rad Outlet to T-Stat Hsng Hose, None visible, hole in tang 1990, T-Stat Hsng to Water Pump Hose, Housing end black clamp "X" Made in Germany Screw Clamp markings NOHMR 32-50 unfortunately I don't have the originals off my 91 I sent an OEM kit to Marc and he changed them not sure if he used the clamps in the kit or put the originals back on.
02-28-2014 | #13 | |
All of the other hose clamp applications I have examined, have been marked "CANADA TRIDON ALL STAINLESS". This is good info that will someday provide useful information for restorers. Keep it coming. =D>
02-28-2014 | #14 |
In the service TSB hose & clamp package the one worm clamp
Made in Germany Screw Clamp markings NOHMR 32-50 is also included. |
03-01-2014 | #15 |
Jerry,
Here are the factory installed hose clamps that came off my 94 #390
03-01-2014 | #16 |
Phil, the engineer in you is showing up..........big time!! Thank you.
03-01-2014 | #17 |
Phil,
You obviously had some free time on your hands today.....LOL!!! Rich
03-02-2014 | #18 |
Jerry,
I'll check my NCRS manual to see what they say about the clamps and report back. John
1968 convertible Lemans Blue, 1986 coupe Medium Blue NCRS Top Flight (sold), 1990 ZR1 #2529 Red NCRS Regional and National Top Flight (sold), 1990 ZR1 #2124 Charcoal Metallic NCRS Top Flight 2010 & 2018, 2003 Anniversary Red Convertible (sold) |
03-02-2014 | #19 |
That would be great. Thanks. IF I remember correctly, NCRS checked the hose clamps for the correct date stamping on C2's. So, I'm just drawing on that recollection & assuming the stampings on the ZR-1 clamps may be similarly important.
03-02-2014 | #20 |
Any thoughts on the reasoning behind a single, odd clamp?
