04-15-2011 | #121 | |
Re: Update on my hi-miler Z project
It appears that there's a leak from the oil temperature sender, which I had resealed with teflon tape a few months back - and apparently that's not the correct method. The FSM calls for Loctite 565 on these fittings, so I've ordered some of that and will also re-seal the oil cooler fittings with this correct material. The teflon tape does not appear to hold up well to hot oil.
04-15-2011 | #122 |
Thanks Sammy, turns out you may be in the right neighborhood. Will update after things are re-sealed!
04-20-2011 | #123 |
Andrew any luck ? Daryll
05-01-2011 | #124 |
Daryll, the last 2 times I drove the car, no codes... but yesterday I got a 3-inch long sheet metal screw through a rear tire, so that trip was cut short...
05-01-2011 | #125 |
Ouch! I know how that feels. I've lost three 315's over six years to screws going thru the tire.....it just seems like it's the little things that come along every now & again to make our day an enjoyable one!
05-01-2011 | #126 | |
I hear that lost a few the same way. Those big tires have a big footprint. Let hope everything else is smooth sailing Andrew
05-04-2011 | #127 |
Hey VetteMed,
how are you liking that Arc Audio Mini amp? I am looking to swap from my Arc 300.4 to the same one you have, mainly due to space constraints.. what are your opinions on that amp of yours?
1990 Corvette ZR-1 #1051 Watson Headers (2" Primary) - Borla Catback Late Model IH - Plenum Coilovers - 4.10s Custom Interior NCM Lifetime Member #978 |
05-18-2011 | #128 |
Update:
I pulled the plenum once again, to finally get the A/C system up and running. When I pulled the rubber evap vacuum line off of the hard line, I got a handful of black granules. I shook the rubber line, and got a whole bunch more. Turns out the charcoal canister behind the rear wheel took a crap, and sent charcoal all through the line and presumably through the solenoid and into the intake. I'm hoping it didn't score up any cylinder walls too badly.
05-18-2011 | #129 |
Jeff, now that I relocated it out of the storage compartment, it's doing well. it was getting entirely too warm in the compartment. However, I'm only 5'9" so I tend to keep my seat somewhat forward, leaving plenty of room for the built-in fan to cool the amp when mounted behind the driver's seat. It's very powerful and clean for its size.
05-18-2011 | #130 |
Damn, I had a chance at 2 to replace my bigger Arcs and I passed, ah well, I can deal with what i have.. LOL
