01-16-2024 | #1 |
Horsepower difference ?
Heres a dumb question...........the first ZR1's had 375 hp , then it jumped to 400 hp, what change or addition made the difference in horsepower gain ?
01-16-2024 | #2 |
Re: Horsepower difference ?
The '93 to '95s were rated at 405 HP. I believe the gains were due to some better porting and exhaust also with some chip tweaking but Marc and others could say more definitively. --Bob
01-16-2024 | #3 |
I believe you are correct, porting and some change in cam grinding , gave it the 30hp gain . I know chevrolet used to retard cam timing years ago for emissions and hp reduction to meet standards.
01-17-2024 | #4 |
improved intake port alignment. Bit better heads and cams, improved exhaust and header/cats.
405 hp blocks also had 4 bolt mains and all of them were made in 1993
95 390 LPE ZR1 (505 rwhp) LSV = Lingenfelter Super Vette Twin Turbo 2003 Z06 (800 RWHP) |
01-20-2024 | #5 |
>Mild port/polish on intake and exhaust ports.
>better blending of the ports just above the valve seats >Three-angle valve seats >"Sleeve spacer" between the head and injector housings to improve alignment >Revised cam timing but cam profiles remained the same >Revised calibration >New exhaust manifolds...which actually cost 5-hp but went to production to solve a problem with the engine ingesting debris if the cat converter substrate failed at high rpm.
01-21-2024 | #6 | |
01-23-2024 | #7 | |
ZR-1 #638/1991 |
01-23-2024 | #8 |
That's because...... IF & When it does......... it Really is!
Referred to as catalyst reversion. Occurs during engine de-celleration, i.e. lifting throttle with clutch engaged at high rpm. All that's left of the Oil Control Ring lands, is that short section on the left end.
Jerry Downey JERRYS LT5 GASKETS & PARTS http://www.jerrysgaskets.com 1994 ZR-1, Black/Black, Lingenfelter Aerobody, 416cu in, 3.91 gears, coil-over susp, Brembo brakes, etc. 2016 Black-Red, 3LT-Z51 Auto 8-speed. Last edited by A26B; 01-23-2024 at 05:57 PM. |
01-27-2024 | #9 | |
Some of that info came from GM press info that was distributed in the 1993 long lead book. The rest of it came from a conversation I had many years ago with Graham B.
01-28-2024 | #10 |
Oh wow. Have to assume that happened to a few cars until someone figured out what was going on?!
1990 Black/Black ZR-1 #1155 1993 White/Red coupe (Regrettably sold) |
