Old 10-13-2023   #1
MRCFOUR
MRCFOUR's Avatar
Default 1991 #614 back from grave but no start, cranks just fine
Hello Z family! So, as you all know, #614 has been in reassembly mode since November of 2022. So, this week we decided to try and get it running. After, tear down of PS header to replace and reposition gasket so that the manifold studs could be installed, various mystery leaks involving the V drain tube, repair and verify all secondary vacuum hoses, removal and cleaning of contacts in starter, replacing ignition coils (verified spark at all 8 plugs), verifying of fire order, removal and testing of alternator, replacement of spark plugs and fuel filter and new single pump from DL Merrill (now have 50-55psi at crank with 45 and eventually lower after crank) setting of TPS voltage, and 2 different PROM chips we are at this stage?. Cranks, does not run unless throttle pedal is lightly feathered, back fire out of headers and TB, smoke puffs out of TB during cranking. Any insight would be greatly appreciated. This car has been off the road since 2019 and was bought in pieces so to be here at this stage is simply a marvel.
HELP! We are at our knowledge base limit and do not know what else to do. Replacement of injectors will be our next step unless this is something silly we are missing.
Thanks so very much!
1991 #614 Black/Saddle - still in rebuild stage since 2021
1992 Coupe Base White/White - ZF6 and a bunch of other modified stuff
1990 Convertible Black/Black/Black - slightly modified
1992 Coupe Black Rose - in and out
1993 Coupe Black Rose - also in and out
MRCFOUR is offline   Reply With Quote
Old 10-14-2023   #2
Default Re: 1991 #614 back from grave but no start, cranks just fine
I would double check and make sure spark plug wires are connected to correct coil terminal.
Old 10-15-2023   #3
viper107
viper107's Avatar
Check fire order also
Old 10-15-2023   #4
viper107
viper107's Avatar
Also if you have a different ecm try that, they junk
Old 10-15-2023   #5
MRCFOUR
MRCFOUR's Avatar
Yes, firing order was gone over many times during plenum install. I have the OE wires that are numbered. Made it easier.
Old 10-15-2023   #6
MRCFOUR
MRCFOUR's Avatar
I?m trying to locate one to do just that. In the meantime, I?m sending mine to Marc to see what?s what with it.
Thanks for the ideas!
Chris
Old 10-15-2023   #7
MRCFOUR
MRCFOUR's Avatar
Thanks. This was gone over many times prior to plenum install. Used the FSM diagrams and I have the factory numbered wires.
Old 10-15-2023   #8
tpepmeie
Chris, I have an ECM I can loan you. I may be down your way in the next week.
Todd
____________________________________
*** our email address has changed!
info@pepmeierengines.com
pepmeierengines.com
Friend us on Facebook too: www.facebook.com/profile.php?id=100011443683384
Pepmeier Engine Development
Old 10-15-2023   #9
MRCFOUR
MRCFOUR's Avatar
This would be fantastic! I?d really like the opportunity to see if indeed that is the issue! If you know when you?d be down this way, we could just plug it in and see what happens!
Chris
Old 10-19-2023   #10
phrogs
phrogs's Avatar
If the Different ECM doesn't work bring it to me ill take it off your hands. haha
Anyway how disassembled was this car when you got it? Is there any chance there's a issue with camshaft timing?
Injectors could really be an issue, I had a set of FICs on the shelf for a few years when I went to use them in my abandoned ZR-1 one of them decided to leak. like just a faucet of fuel dumping out of it, Of course I failed to double check them so I had to yank them out and test them and that's how I figured it out. with no input from the car other than fuel pressure. So perhaps you have a leaker or not even spraying. Of course the ECM could be the issue but I would have your injectors tested. If you want to send them to me I could do it see what they are doing before you buy new ones.
JOHNNY P
Currently own
