Old 11-06-2019   #11
Gunny
Gunny's Avatar
Default Re: brake question
If you can get past the brand name, take a close look at Ford's PM-1-C High Performance Dot 3 brake fluid. That's all I used in my 90 ZR-1 and 94 LT1 (with upgraded ZR-1 brakes). I installed Russell speed bleeders and changed brake fluid prior to a track event/mountain run or annually, whichever came first. With the speed bleeders I could bleed all 4 in less than 15 minutes & didn't have to bother the wife to pump the brakes -- trust me, it was easier to install the speed bleeders than explain to my lovely bride the importance of bleeding the brakes so frequently.
George Jones
Founding Member #14
www.zrwon.com
Gunny is offline   Reply With Quote
Old 11-06-2019   #12
spork2367
Prestone Dot 4 exceeds the specs on that and is cheaper.
Old 11-06-2019   #13
lfalzarano
Gunny, how do you know when all the air is pumped out? Dumb question from when I did it as a two man job...[emoji16]
Lou[COLOR="Red"][B][SIZE="4"][/SIZE][/B][/COLOR]
