12-06-2016 | #1 |
New ZR1 Owner With Plenum Vacuum Question
Bought my first ZR1 a few weeks ago and am trying to get it running right.
I pulled the plenum and replaced the injectors and coils. I almost have it back together, but don't know where the plug on the rear connects (points to firewall). Is there a hose above the bell housing I can't see? I have a pic, but am having issues uploading it. |
12-06-2016 | #2 | |
Re: New ZR1 Owner With Plenum Vacuum Question
See if this answers your question.
12-06-2016 | #3 |
Thsnks for the pic. It is the vacuum line that goes to the MAP sensor. It sure is frustrating when you methodically remove parts, then something disappears when you go to reassemble. Not sure what happened to the hose.
12-06-2016 | #4 |
Your hose probably ran off with my socks!
