#11 |
![]() Join Date: Mar 2014
When the PO pulled up to the tag place 2 1/2 years ago in bright sunlight, my future Black Z looked like a swirling machine.....It was the first time I saw it in the sun. Although the day I first saw the car, it was in his garage and raining outside. Looking at the paint with my trusty cell phone flashlight, I could see that there were swirls in the paint, but didn't even think that they were as bad as they were.
That being said, I knew I had my work cut out for me. Still working at the time, did what I could when I could. Now you have to understand that I have enough polishes, waxes, compounds, etc., to last me for 3 lifetimes.....and I am a sucker for new products. So I tried what I had and was only semi-happy with the results. Although I will mention the products that have and are working for me now, this is not to say that they are end-all-be-all. As there are many fine products out there that will deliver excellent results, you just have to experiment and find what works for you. I decided to give Adams Paint Correction and Finishing Polish a try. Used my orbital buffer and went to work. Did the process 2 times. Time consuming, yes, but worth the effort. Did it eliminate all of the swirls, no, but it made quite an improvement. So not wanting to have a more comprehensive paint correction process done at a shop, I stumble across Turtle Jet Black Spray Detailer. After my own paint correction, I decided to give it a try, well let me tell you, it works. The label states that it will fill in swirls and marks, it does. So then I find Turtle Jet Black Wax for "Black Cars", and it works nicely as well. Can't tell you how many coats of spray wax and detailer are now on the 94, but it is a vast improvement of what it was 2 1/2 years ago. Not a show quality paint, but for original and its life history, I am happy with the way it now looks. ![]() ![]()
Tom 1994 ZR-1 #009 "captured test fleet car" 1974 LS4 454 Vert 1982 L83 CFI...now a retired "dd"....Sold WAZOO Member Last edited by Roadster; 10-13-2016 at 01:07 AM. |
#12 |
![]() Join Date: Nov 2014
Hey Roadster were you at Carlyle in August? I was there Thursday and Friday at the Registry tent.......I believe I did see this car parked also there.....I said to myself - I have to get my paint to look like that".......
Sorry I did not get a chance to formerly meet you if in fact that was your car on the field........Thanks for the tips.......Heard good things about Black magic so maybe I will give it a try since its readily available at auto zone... |
#13 | |
ZR-1's. Although I lost some pics ![]() ![]() Turtle Jet Black (Spray Detailer & Spray Wax) is what I recommend, not Black Magic, which may be another brand. But I do suggest doing some type of paint correction, as mentioned above before using the Turtle Jet Black products that are listed here and above. And it is a time consuming process, especially if your not familiar with using a buffer. Plenty of You Tube videos to check out on this subject. Keep us posted!!!
Tom 1994 ZR-1 #009 "captured test fleet car" 1974 LS4 454 Vert 1982 L83 CFI...now a retired "dd"....Sold WAZOO Member Last edited by Roadster; 10-13-2016 at 01:09 AM. |
#14 |
I just purchased a black 1990. There was plenty of wax on the car, but what appeared to be compound haze underneath. I clayed the car and first tried Griots Garage One-Step Sealant applied with a DA. It continued to leave a haze. I then tried both Meguiars Ultimate compound & polish with the same results. The only thing I was successful with was Zymol applied by hand. I followed that with Meguiars GoldClass past wax applied by hand.
#15 |
Reviving an old thread.
The new Turtle Wax Hybrid Solutions Ceramic black polish & wax have been receiving great reviews so I decided to try them. I am very impressed with the results. Although the polish was a PITA with hazing, it did a great job removing swirl marks. I only did a few areas by hand. The product may work better with a DA. The application and removal of the wax was a little unique but easy (follow the directions). The paint is smooth as glass, looks deeper, and is a tiny bit "blacker" than with the Meguiars Gold Class paste wax I have been using. ![]() |
#16 |
![]() Join Date: May 2010
[emoji33] Wow! That looks amazing! Thanks for sharing; I?ll have to try it on my Black Z. [emoji1303]🤙🏼[emoji847] Sent from my iPhone using ZR-1 Net Registry
#17 | |
![]() Join Date: Sep 2008
Only suggestion might be a more multi step polish regimen. Paint correction (polish) needs to be sufficiently aggressive to remove the imperfections, then less aggressive to remove the finer scratches from the aggressive polish. Here we go through either a 3 or a 5 step correction process, as light as needed to get out all of the imperfections. It takes 1-2 days to get the car where I find it acceptable. The practice of putting a genuine wax product over the synthetic products is what really makes it look absolutely amazing! The Gloss Enhancer sprays mentioned in the original post take it up even further. I have no experience with the newer Turtle products. I avoid ceramic coatings after discussing with my painter. Most need to be sanded off to fix even a scratch. So in a case where you are trying to panel blend, you may need to sand a good portion of the car to repair a simple scratch. I have found X-Pel to be a far better way to protect paint form damage and it is reversible. Make it look great! ![]() Marty |
