05-06-2014 | #91 |
Re: Mountain Run 2
05-06-2014 | #92 |
Re: Mountain Run 2
This is my first long trip with my Z. Can anyone suggest what tools to bring along and spare parts,
. Thanks, Nelson 007
WAZOO MEMBER 1993 #124 Ruby 1994 #??? Red/Black 1995 #061 Black/Red 2012 ZR1 Preproduction |
05-06-2014 | #93 | |
Re: Mountain Run 2
An AAA card is not a bad idea either. FWIW: I carry a scissor jack, tire plug kit (a good "gun" type w/mushroom plugs), a can of Green Slime, tire guage, wire cutters (to pull out the nail or whatever), a small 12v compressor, gloves, flashlite and a breaker bar w/deep socket (for jack and lugs). It all fits in the compartment behind the right seat. Unless I tear a hole in a tire, with this maybe I can keep going. Check the air in your spare too, even though I'd try to avoid using it if at all possible. See ya Sunday! |
05-06-2014 | #94 |
Re: Mountain Run 2
What Doug said ... plus
if you have a spare serpentine belt, it's a good idea to keep it in the compartment behind the seat. I usually carry a small array of sockets, extensions, ratchets, wrenches, torx bits, etc. I picked up a couple of plastic tool boxes from Sears that hold most of what I need and are compact enough to carry easily ... I believe they are compact truck boxes Item # 00965117000P Model # 65117. The nice thing about this trip is the number of knowledgeable "mechanics" available should anyone need some help. |
05-06-2014 | #95 | |
Re: Mountain Run 2
Thanks for the suggestions. Your right about the knowledgeable mechanics, sad to say i am not one of them.
Nelson007 Quote:
05-06-2014 | #96 |
Re: Mountain Run 2
I bring an alternator, serpentine belt, gaskets, coil packs, injectors and water pump. Tools of course.
Robert J. DeMarco [SIGPIC][/SIGPIC] [COLOR=blue]G[/COLOR][COLOR=red]rand[/COLOR] [COLOR=blue]S[/COLOR][COLOR=red]port[/COLOR] Registry Lifetime Member NCM Lifetime Member #2655 Pacecar Registry Member [COLOR=red]ZOOM Charter Member - ZR-1 Owners of Michigan[/COLOR] [COLOR=plum][I]ZR-1[/I] Registry member since 2012 [/COLOR] [COLOR=black]1990 LPE "368" Aerobody ZR-1, Last ZR-1 built by John[/COLOR] 1991 Callaway Aerobody ZR-1, DRM 500 1991 Shinoda Aerobody Spyder, 1998 Pace Car |
05-07-2014 | #97 |
Re: Mountain Run 2
Motorhome with a 35ft trailer?????????
05-07-2014 | #98 |
Re: Mountain Run 2
I'll have the usual-
Good carz, good food, good friendz = the best of timez! 90 #1202 "FBI" top end ported & relieved Cam timing by "Pete the Greek" Sans secondaries Chip & dyno tuning by Haibeck Automotive SW headers, X-pipe, MF muffs Former Secretary, ZR-1 Net Registry Last edited by Paul Workman; 05-07-2014 at 08:21 AM. |
05-07-2014 | #99 |
Re: Mountain Run 2
05-07-2014 | #100 |
Re: Mountain Run 2
Hey Gunny, have you made reservation's at the restraunts? 20 people is bit of a hit.
