10-11-2013 | #11 |
Re: I discovered how to easily drain the oil cooler! (on my 91' at least)
10-11-2013 | #12 | |
Dave; is tube configuration different for the 2 different coolers?
I'm getting my snappics / threads removed blindly as fast as I can, to get in compliance with copyright / license TOS on the boards here (lots of FSM pages and other copyright / license violations on my part; sorry guys). And thanks to all the guys who didn't whine when I posted those FSM copyrighted / licensed stuff in my threads... ( :thumbsup: [b]and to think I complied with a mod's request to delete a pic of him in a Challenge Car in NCM Museum, so he wouldn't get in hot water)[/b] Thanks to several guys here for sending parts FREE; BearlyFlying, WeGone, Geezer, GoldCylon, and more there, TonyD, mike100, fletchusmc... 1990 #2794; 4L60e Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless, Power Effects 3" [IMG]https://lh5.googleusercontent.com/-GHpfzty7DVU/UQn-0Ru2xAI/AAAAAAAAA14/08mz1p4QLD4/s445/Screenshot-5.png[/IMG] |
10-12-2013 | #13 | |||||
Summary of Oil Cooler Drain Plug
I would expect that the flow through the Oil Cooler is of such significant velocity/pressure that contamination deposits would not STALL in the bottom of the Oil Cooler. Such accumulation of contamination deposits could over time close off the oil cooler. My thinking is that such deposits would be cleared by force (oil pressure and hydrodynamic cleaning) within the oil cooler narrow passageways. I am also thinking the Oil Cooler Flow is Filtered just after the Oil FIlter (just thinking). Quote:
Meaning that Oil Cooler Part # 10219643 (94' and 95') does not have the Drain Plug. This Oil Cooler information is for a your 1994 I am assuming
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 10-12-2013 at 10:48 PM. |
10-12-2013 | #14 |
If I recall correctly, the oil cooler is not in the full flow path until the oil temp thermostat in the oil filter adapter opens. Prior to opening, the oil flow to/through the oil cooler is minimal, so that when the oil t-stat does open, the cooler is fully charged.
That is why you will not see any abnormal pressure lag after an oil change with an empty oil cooler, as mentioned by the OP.
10-12-2013 | #15 | |
10-12-2013 | #16 | |
Is this a service-able item, that warrants a maintenance eye?
10-12-2013 | #17 |
I agree with Jerry that the oiler cooler is only in the flow path when the oil temp thermostat begins to open. As I mentioned above my 94 model year oil cooler did not have any kind of a drain fitting. For flushing the cooler I filled it with clean solvent through the inlet and return ports at o-ring flange connection then shaked the cooler back and forth to work the solvent through the tubes then cleared it with compressed air. Initially I was surprised how many times I had to repeat the process until the solvent came out clear. Appears to me that over time and miles thickened oil and the usual oil born sediments accumulate in the bottom cooler header tube. After thinking about it I do not find this unusual. If this were an oil cooler from a industrial engine like we see at work no attempt would made to clean it. Instead it would be replaced with a new cooler.
10-12-2013 | #18 | |
Jerry - That's what I recall Tyler mentioning also and I didn't comment BUT had this question. If you drain 60 oz of oil and add 60 oz to the conventional fill the crankcase is 60 oz overfull until the t'stat opens which I thought Tyler mentioned as "seldom"? The 60 oz "over-fill" I think needs to be considered here as "compromised" and possibly "catastrophic". I used a 60 oz number assuming that was what might be measured in the draining not anticipating the 64 oz capacity as "gospel". So your only option would be to do the conventional fill and then watch for a "low level" on the dip stick? I just can get past the "conventional" wisdom that has prevailed for years. Am I missing something? |
10-12-2013 | #19 | |
and this is good info too... Quote:
I'm getting my snappics / threads removed blindly as fast as I can, to get in compliance with copyright / license TOS on the boards here (lots of FSM pages and other copyright / license violations on my part; sorry guys). And thanks to all the guys who didn't whine when I posted those FSM copyrighted / licensed stuff in my threads... ( :thumbsup: [b]and to think I complied with a mod's request to delete a pic of him in a Challenge Car in NCM Museum, so he wouldn't get in hot water)[/b] Thanks to several guys here for sending parts FREE; BearlyFlying, WeGone, Geezer, GoldCylon, and more there, TonyD, mike100, fletchusmc... 1990 #2794; 4L60e Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless, Power Effects 3" [IMG]https://lh5.googleusercontent.com/-GHpfzty7DVU/UQn-0Ru2xAI/AAAAAAAAA14/08mz1p4QLD4/s445/Screenshot-5.png[/IMG] Last edited by Schrade; 10-12-2013 at 12:59 PM. |
10-12-2013 | #20 |
Another point, the oiler cooler by itself does not account for all the oil that cannot be drained. The oil cooler volume on my 94 is around 1.4 quarts.
