09-21-2023 | #1 |
No start help!!
I have a strange problem?
I ordered up all new injectors from FIC and installed them, fun stuff. Took my time, disconnected the battery and everything. No I have a no start problem. Pretty sure it?s not the injectors, I smell fuel and had a fuel pressure gauge on the rail, shows a drop in pressure as it cranks. Put a coil tester online with a spark plug? no spark! Pull the plenum back off to check all my connections, even took them off to make sure no bad connectors, put back together. Still no start. No codes come up, fuses are good, key on, security light is off?. What am I missing? Please help! |
09-22-2023 | #2 |
Re: No start help!!
You're positive everything is plugged in?
Check for bent pin on the ignition module that pain in the *** that's on the plenum.
JOHNNY P Currently own 90 ZR-1 #845 DRM 500 engine package 90 #226 Might be a parts car not sure yet |
09-22-2023 | #3 |
Re: No start help!!
Checked everything. May have to pull it apart a third time!!
09-22-2023 | #4 |
Re: No start help!!
Welcome to the brotherhood. Been there done that.
09-22-2023 | #5 |
Re: No start help!!
As Phrogs Said Double check the pins on the Ign. Module !!
09-23-2023 | #6 |
Re: No start help!!
Just in case it's not entirely clear, the ignition module is the device that lives on the bottom side of the plenum.
It's also known as the DIS module. It has connectors in front and the back. It's very easy to bend a connection pin on either of the plugs, especially the one on the back. Suffice to say, it is a serious design flaw, that really should never made it into production. Given all the other stuff going on under the plenum, it's the only thing that will stop the coils from firing. Good luck!! Crabs
TomC '90ZR1 #792 Honorary Pirate [B]If it ain't FUN, you're doing something terribly WRONG. [/B] Last edited by tccrab; 09-23-2023 at 10:07 AM. |
09-26-2023 | #7 |
Re: No start help!!
Check inj 1 fuse, is it blown?
If yes, you may have pinched an injector wire in between the upper and lower plenum. Start there, a dead inj 1 fuse signifies a grounded hot wire to the injectors, coils, control module.. easy check John |
09-27-2023 | #8 |
Re: No start help!!
its definatly somthing you had your hands on,so back apart you go
95 admiral blue z(sold)/ / 93 ruby z(sold) 91 steel blue z/95 aqua z haibeck 510, 91 callaway 415 areobody #5 |
