09-12-2019 | #1 |
1955 Ford F-100 Metallic Blue with Silver Flames 514CI 600HP
1955 Ford F-100 Metallic Blue with Silver Flames and Matching Silver Interior with Blue Accents.
Yes, I know that it is not a Corvette. I limit Non Corvettes to 5 cars. However, you can be certain that any of those 5 are without a doubt, the best of their class. This outrageous truck is no exception. It begins with a custom built frame and a suspension consisting of Heidts Super-ride II with Air-Ride both Front and Rear. The Differential is a 9 Inch Four Link unit with Posi Traction of course. A C-6 Automatic Transmission with a 2000 Stall Speed Converter. OK, what makes it GO? The Engine is a 460 Stroked and Bored to 514 Cubic Inches! Super Cobra-Jet heads, Stainless Steel Valves, Weiand Stealth Intake with an 800 CFM Carburetor. Comp Cam Hydraulic Cam with Roller Rockers. H-Beam Rods, Keith Black Pistons, a 10:1 Compression Ratio and much much more. Yes, it GOES! Also Equipped with Four Wheel Power Disc Brakes, Power Steering, a Painless Wiring Harness, Weld aluminum Wheels, New Glass, a complete set of Auto-Meter Gauges, Power Windows, a Killer sound system, AND Vintage Air! Much, Much more, but you now are beginning to see why this is here! Well over $100k into the build of this head turning simply stunning vehicle! Only 558 Miles since it was completed!! Your chance to acquire a True Turn Key Custom High Performance Truck that is also Very Well Priced!. . . . . .$59,900. . . . . follow this link for 20 pictures of this incredible truck: http://www.contes.com/index.php/new-...em/197-new-car Thanks, Marty |
