![]() ![]() Join Date: Nov 2007
The corner of Ami's smoked glass top was broken and glued(?) Back on. But, the repair is visible (maybe only to a blind man on a galloping horse...).
I think if there was a filler of some kind, I believe I have the tools to buff it out. Can anyone point me in the right direction? TIA ![]() Paul
![]() Join Date: Jan 2011
Paul give this a try. I have used it on T-tops, targa tops and jewelery with good results.
https://www.resinobsession.com/resin...the-difference |
Thompson Astro Tops
1422 Huntsville Rd Florence, AL 35630 Phone number (256) 764-0659 |
Paul,
There's Melrose T Tops in Cortland.
#5 | |
![]() Join Date: Sep 2008
ANY repair will still be easily seen by the blind person on the galloping horse, and cheapens the look of the car. Those roof panels are subjected to a lot of torsional force as the car moves over bumps and potholes. Once it is compromised, it is likely to remain that way. Yours can be rebuilt, or best to just use it as a core for return. Melrose or Thompson as others said, both are fine as long as you select the factory replacement version. Like Nike; Just do it. Then enjoy the new top! ![]() Marty |
U can't unbreak an egg.
![]() Join Date: Jan 2015
This is a bit of a tangent, but hopefully related enough ...
If you buy a protective storage cover for your targa top, look closely before ordering. I was very disappointed when I found my new cover left the vulnerable corners exposed. It's easy to set the top down on one of the corners and chip it. The cover doesn't protect them at all (see lower corners in this photo). ![]() Also, I agree with Marty. My glass top came with a cracked corner, and I stupidly did a few track days with my car and the top developed more cracks. I shouldv'e swapped to my other top for those days. My cracks are hidden (not very well) with black vinyl (like the decal material). It looks okay from 15' away. |
![]() Join Date: Jan 2010
The corners of the storage bag are left
"exposed" to allow it to fit in the fixtures in the rear storage compartment |
![]() Join Date: Nov 2013
I'd be curious too. Mine has a 1" crack on the front drivers corner. Along time ago I had a 95 I bought a Astro top for, was a big piece of crap compared to the original. Melrose has some good reviews but never looked at one up close.
1994 ZR-1 #198, sold [img]https://live.staticflickr.com/65535/48400173802_2a6f122cfb_n.jpg[/IMG] [COLOR=RoyalBlue]96 GrandSport#857[/COLOR],[COLOR=Red]Red Gut[/COLOR] 397 LT4, AFR heads,3:90 gears, DRM longtubes, Sepanek 700R4, Yank 3600, bla-bla... Best ET w/396 & 6-speed 11.02 @126.57 w/1.60 60' Best ET w/396 & 700r4 10.82 @124.87 w/1.48 60' 2003 DarkShadowGray Ford Lightning 460rwhp/550rwtq 12.11 @112.18 w/1.71 60' |
#10 |
![]() Join Date: Nov 2011
