Old 02-27-2011   #1
mgbrv8
Default Beam plate torque
I finished making my beam plates. What torque spec should I use when torqueing them down?
Dave
Old 02-27-2011   #2
karterdon
karterdon's Avatar
Default Re: Beam plate torque
It depends on the size and type of bolt used????
karterdon is offline   Reply With Quote
Old 02-27-2011   #3
mgbrv8
The factory c-beam bolts
Old 02-27-2011   #4
ZR1Vette
ZR1Vette's Avatar
Ft lbs spec:
59 for the carrier
here is the end for this spec>>
37 for the tranny end
Assumes reusing OEM bolts and using OEM spec'd nuts
Old 03-01-2011   #5
mgbrv8
Okay the beam plates are in should I do any aligning on the rear end and tranny before I start torquing them down??
Dave
Old 03-02-2011   #6
Originally Posted by ZR1Vette View Post
Ft lbs spec:
59 for the carrier
Damn thats clean looking underthere!!!!
Old 03-02-2011   #7
Yes it is!
Makes me envious.....mine used to look like that....when it first came off the truck 42k miles ago.
Old 03-02-2011   #8
ittlfly
An undercarriage looking like that is a sign of a sick mind.
ittlfly is offline   Reply With Quote
Old 03-02-2011   #9
ZR1Vette
ZR1Vette's Avatar
Plead guilty to a somewhat demented mind... also it was a good start when I purchased the ZR 2+ years ago and had only 1320 miles of the odo
Old 03-02-2011   #10
.....and now it makes me feel bad looking at mine..... and it took years to get used to it.
Wish I had a neighbor with OCD!
A26B is online now   Reply With Quote
