06-08-2015 | #1 |
WMD - Saturday - 13 June 2015
I am scheduling a Westminster Maintenance Day on Saturday, 13 June 2015 at my garage in Westminster, Maryland.
We will be working on rear wheel bearings and shocks for Charlie, and if we have time we will install C-Beam plates for Scott. If you have anything else you want to do to your Z, please let me know. Start time is 9:00 AM but come when you can and stay as long as you like. Come and hang out with us. Location: In the garage behind my house at 195 W Main St, Westminster, MD If you need directions of have questions, contact me at 443-244-1347 of jim@gizmosart.com Jim
If it isn't fun, you aren't doing it right! 1990 Black ZR-1 - sold 1993 Quasar Blue ZR-1 1994 Competition Yellow ZR-1 1995 Dark Purple ZR-1 Maryland State Coordinator WAZOO Member |
06-09-2015 | #2 |
Re: WMD - Saturday - 13 June 2015
Hi Jim,
I'm not sure yet if I will be able to make it this Saturday. Have a great time if I don't make it. Thanks, Matt
Matt Glyder "93 Vette" WAZOO Member 1991 ZR-1 - Artic White/Red #1252 1991 ZR-1 - Dark Red Metallic/Saddle #1817 2018 Grand Sport Coupe - Admiral Blue/Red & Black 1988 Corvette Challenge Race Car - Red/Black #66 (Co-owner with Dad) 1993 LT1 Coupe - Arctic White/Black (SOLD 5/31/15) |
06-09-2015 | #3 |
Can't make this one fellas, I could tell you why but then... Well you know...
90 ZR-1 #0951 Bright Red (sold) 06 Z51 MN6 Velocity Yellow (sold) 2023 C-8 Z51 ELB WAZOO Member |
06-09-2015 | #4 |
I should be there a little late... can't make the 0900 start due to a swim meet. Looking forward to seeing everyone again.
Scott
WAZOO Member '95 Callaway SNAT 450 Aerobody Coupe - Black/Black '92 Callaway SNAT 400 Convertible - Polo Green/Beige '91 ZR-1 #1231 - Arctic White/Saddle (SOLD) '90 ZR-1 #2547 - Turquoise Metallic/Black '89 Callaway Twin Turbo Aerobody Coupe #027 - Black/Black '85 Corvette 454 Coupe - White/Red |
06-09-2015 | #5 |
Headed to the in-laws in Cape May to do some chores for them.
I will make one this year!
John Porter '93 Ruby Coupe ZF6 - Muffler eliminators, Blink Blink kit and Polished ZR1 Wheels * PA Plate: OBSSSN '06 LeMans Blue C6 Coupe - Corsa exhaust * PA Plate: OBSSSV ZR1 Net Registry Founding Member #153 40th Anniversary Registry Member NCM Family Membership #8116 Corvette Forum NE Events Coordinator Delco Cruisers Board of Directors SAVE THE WAVE! |
06-11-2015 | #6 |
Sorry... Can't make this Saturday. I'll be down at VA Beach getting baked.
06-11-2015 | #7 |
I'm trying to work it out so that I can come for a few hours in the morning.
Matt
06-11-2015 | #8 |
I'll be there.
Nelson
WAZOO MEMBER 1993 #124 Ruby 1994 #??? Red/Black 1995 #061 Black/Red 2012 ZR1 Preproduction |
06-11-2015 | #9 | |
Some other items just in case......And make sure you remove the washers on TOP of the C-Frame (did that also) C4 Beam Plates and Installation C4 Beam Plate Installed On Differential ......................C4 Beam Plate Installed On Transmission .................................................. ................................Note C4 Beam Plate Bevel Location 5. Why Take Measurements? It is kind of a corny measurement since you are measuring between the C-Frame and the side wall/Underbody which is heavily coated and made of light steel and the accuracy of the measurement needs only to be within 1/4 inch + or -. I think you are just making sure you did not put an angle in that front driveline U-joint by moving the transmission appreciably during the installation of the new C4 Beam Plates. A Quick Measurement in regard to Transmission Yoke height can be checked from inside the car by measuring the height of the Shifter. A height of 6.25 inches from the counsel to the top of the shifter (at the center of the shifter in neutral) will be very close to the correct transmission height. a. The 1.77 in spacer should fit between the top of the driveline support to the underbody. The 1.1 in spacer should fit between the right side (passenger side) of the driveline support to the side wall. b. You might check that alignment spacing before you start the project to see where your alignment is now. Then just keep that alignment with the installation of the new C4 Beam Plates. Secondary to Transmission/Driveline Alignment is ground clearance of Transmission Drain Plug. The Transmission Drain Plug clearance to ground is approximately 4 to 4.5 inches on my ZR-1s which is NOT the lowest point on the ZR-1 Drive Train/Chassis. The Ground Clearance depends on many things including Tire Pressure, Tires, Wheels, and Suspension. 6. Re-Installing the Exhaust. The Exhaust System can be re-installed after the C-Beam Plates are torqued and the front Exhaust Hanger is re-installed in the location of the Front C-Beam Plates. The Entire Exhaust System can be reinstalled by sliding the Exhaust System under the ZR-1 and setting a rolling hydraulic jack under the rear of the center Exhaust and lifting up to within about 8 inches of the final position. A. Lift the two rear Tail Pipes and slip the slider into position on the slip joints. Slide the Entire Exhaust System to the rear of the ZR-1 about 1 inch completely engaging the slip joints holding the Tail Pipes. B. Raise the front of the Exhaust System with the rolling Hydraulic Jack to the final height aligning with the Catalytic Converter Connections. Slide the Entire Exhaust System Forward and install 6 NEW SS 10mm x 1.5 bolts. (10mm x 1.5 x 30mm on Passenger Side and 10mm x 1.5 x 50mm on Drivers Side). The SS Bolts shown have 17mm Hex Heads and Washers are NOT required. SS 10mm x 1.5 x 30mm and SS 10mm x 1.5 x 50mm Bolts C. Reinstall the two Front 13mm Head Hanger Bolts and the two Rear 13mm Head Hanger Bolts.
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 06-12-2015 at 12:05 PM. |
06-12-2015 | #10 |
Thanks Cliff. I have broken several exhaust flange bolts over the years. The good news is that it has always been the bolt that is easy to get to for drilling and tapping.
Regarding the measurements, what would you "adjust" if the dimensions were not what you expected? When I reinstall a C-Beam, I have a rolling jack under the back of the oil pan. Raising the back of the engine changes the angle of the motor and transmission so the back end of the C-Beam can be exactly aligned to the differential. Jim |
