01-07-2023 | #1 |
Coolant hose network issues looking like a pain
Wondering if anyone has a solution for our ZR-1 specific coolant hose to thermostat setup, INCLUDING the connections. The coolant return connection to thermostat housing is leaking on me, so I just ordered a new replacement part off Jerry?s. It is most likely going to involve removing the housing to remove the old part and install. Then I got to looking at the other connection and I do not believe there is a direct replacement available. Hoping someone has found a workaround to these connections including the line set up going to the surge tank.
Someone has to have tackled this problem already. Oldest cars turned 33. |
01-10-2023 | #2 |
Re: Coolant hose network issues looking like a pain
Well I got some views, but no insight just yet. Perhaps I am approaching this the wrong way. Has anyone considered what their options are when, not if, one of the hoses that is a part of an entire assembly no longer manufactured for the thermostat housing and surge tank burst?
The only thing that comes to mind is take the whole assembly and ship it off to Classic Tube as a template and pay a decent chunk of cash for a reproduction of the assembly. Last edited by 1991 Corvette ZR-1; 01-10-2023 at 03:15 PM. |
01-10-2023 | #3 | |
https://www.jerrysgaskets.com/hose-s...ant-6pc-90-95/ Or, is this the part you are referring to?
Jerry Downey JERRYS LT5 GASKETS & PARTS http://www.jerrysgaskets.com 1994 ZR-1, Black/Black, Lingenfelter Aerobody, 416cu in, 3.91 gears, coil-over susp, Brembo brakes, etc. 2016 Black-Red, 3LT-Z51 Auto 8-speed. Last edited by A26B; 01-10-2023 at 05:18 PM. |
01-10-2023 | #4 | |
01-10-2023 | #5 | |
Looks like it is the third picture. It is the whole assembly of rubber hoses crimped into metal hard lines that meet together in front of the surge tank and run along the passenger side skirt down to the overflow bottle and thermostat housing. |
01-10-2023 | #6 | |
