06-29-2022 | #1 |
Fill Plug on Rear Differential
I just swapped out the gear oil in my ?91 with 30k miles and am having troubles getting the plug to properly thread back in. It appears to be the first time it?s been changed and it came off with no problems. I can?t imagine it?s cross threaded but understand it?s a tapered plug. Does anyone have any tips or suggestions?
Thanks! Bryan Sent from my iPhone using ZR-1 Net Registry |
06-29-2022 | #2 |
Re: Fill Plug on Rear Differential
Hmm not sure, how do the threads look on the plug?
JOHNNY P Currently own 90 ZR-1 #845 DRM 500 engine package 90 #226 Parts car Hit me up if you need anything. |
06-30-2022 | #3 |
Threads look fine. I?m able to get it threaded in about half way and then it stops. I?m hesitant to put much more torque behind it in fear that I will cross thread or strip it. Anyone else encounter this? Sent from my iPhone using ZR-1 Net Registry |
06-30-2022 | #4 |
It is a tapered pipe plug. Usually they screw 1/2 to 2/3 the way in. Be sure to put some anti seize on the plug threads.
IMG_2896.JPG Sent from my iPhone using ZR-1 Net Registry
06-30-2022 | #5 | |
06-30-2022 | #6 |
