12-27-2013 | #1 |
F*U* car (just unloaded 9mm on motor).
Well, sort of, anyway here (and the thought HAS crossed my mind here (but that doesn't take long either ) ) .
Good idea there Cliff - after seein' mgbvr8's handy gizmo-bob in operation... So I looked to see if a USB scope could be had (lot$ cheaper, but 20 miles away), and then found one local, for a few $$ more): What car tools have you gotten for Christmas?
I'm getting my snappics / threads removed blindly as fast as I can, to get in compliance with copyright / license TOS on the boards here (lots of FSM pages and other copyright / license violations on my part; sorry guys). And thanks to all the guys who didn't whine when I posted those FSM copyrighted / licensed stuff in my threads... ( :thumbsup: [b]and to think I complied with a mod's request to delete a pic of him in a Challenge Car in NCM Museum, so he wouldn't get in hot water)[/b] Thanks to several guys here for sending parts FREE; BearlyFlying, WeGone, Geezer, GoldCylon, and more there, TonyD, mike100, fletchusmc... 1990 #2794; 4L60e Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless, Power Effects 3" [IMG]https://lh5.googleusercontent.com/-GHpfzty7DVU/UQn-0Ru2xAI/AAAAAAAAA14/08mz1p4QLD4/s445/Screenshot-5.png[/IMG] |
12-27-2013 | #2 | |
Re: F*U* car (just unloaded 9mm on motor).
Yep........The Bore Scope is super and I used it to make sure I did not drop something into the cylinders....and checked the cylinder walls....SUPER
If you want to take a look at what is under the plenum or check your brake pads..........The Wireless Bore Scope is ideal Wireless Bore Scope Quote:
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 12-27-2013 at 09:26 PM. |
12-28-2013 | #3 |
Pretty slick
12-29-2013 | #4 |
A true mechanic
Busted knuckles |
12-29-2013 | #5 |
These are fantastic......broke a valve spring on the z06 couple years back, went down inside the spark plug hole to make sure no piston to valve contact occured.
It did the trick and confirmed no damage, saved me from pulling the head. |
12-29-2013 | #6 |
Cliff where did you pick that up? Are you in CA now?
12-29-2013 | #7 |
BOY-YO-BOY, I can see a couple dozen times I could have used one of those! Gonna have to look that one up; check 'em out. (Possibly use as a bore scope too (on bigger firearms, doanchaknow).
Thanks for the post!
12-29-2013 | #8 |
Ebay.....very similar to this http://www.ebay.com/itm/Whistler-9mm...item4d16c18e43
Yes.....CA And I forgot to bring the wireless inspection camera back to CA
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 01-04-2014 at 06:14 PM. |
01-04-2014 | #9 |
Picked one up at Harbor Freight for $59
01-04-2014 | #10 |
Constantine Registry Founding Member #0235 1991 Corvette ZR-1 -- Stock, 94 ZR-1 exhaust system, muffler delete. 1956 Chevrolet Belair -- Pro Street, 531ci Cadillac, 8-71 Blower, 8pt roll bar, built TH-400, 9" rear, 1,100 HP -- Street Car. https://www.youtube.com/watch?v=z8y4cwcvK0s 1968 Mustang "Pegasus" -- Zeeker Chassis, 584ci Dart Block, Brodix Big Brodies, 2-1150 Dominators, FTI 'Glide, 1168 hp, best ET & Trap(holding back) 8.57@159 -- 7.9X -- 1/4 mile car. 1970 Chevelle -- 468ci, TKO600, shaved and smoothed everything. |
