Go Back   ZR-1 Net Registry Forums > C4 ZR-1 > C4 Members' Rides
Old 04-27-2023   #1
AlbanyBrian
Default A couple pictures from 4-25-2023
It was a nice day in western Oregon. So, with the troubleshooting of the stumble or misfire done and the issues resolved the car is running well. Took it for a drive in the morning to enjoy some dry roads and sunshine. Stopped and took a couple photos at Thompson's Mill near Shedd, Oregon.
Brian
AlbanyBrian is offline   Reply With Quote
Old 04-27-2023   #2
Mikey
Default Re: A couple pictures from 4-25-2023
Lookin good
Old 04-27-2023   #3
hiperf406
hiperf406's Avatar
Very nice.
lorne # 1748
Stock except for a modified Corsa exhaust.
When the flag drops the bull sh1t stops!
hiperf406 is offline   Reply With Quote
Old 04-28-2023   #4
1977CamaroZ28
1977CamaroZ28's Avatar
Red with black wheels... Nice combination
1.990 Chevrolet Corvette ZR-1
#2342 - Black/Black - March 1.990 -
OBX Headers and OBX complete Exhaust Line (No Cats).
K&N Air Filter with open Air Box.
Jerry's Gaskets Silicone Air Duct.
DeWitts Two Row Pro Series Radiator.
Samco's Hose Coolant Kit.
ECM/EPROM Improved.
MSD Spark Plug Wires 8,5mm Super Conductor.
EBC Brakes YellowStuff with EBC D-Series Rotors and Raybestos hoses.
1977CamaroZ28 is offline   Reply With Quote
Old 04-28-2023   #5
Figure8it
Figure8it's Avatar
Awesome! It?s great to enjoy the better weather. Winter hurts
1992 Polo Green ZR-1, DRM500
Figure8it is offline   Reply With Quote
Old 07-31-2023   #6
f2892704
Nice color
f2892704 is offline   Reply With Quote
Old 07-31-2023   #7
dredgeguy
dredgeguy's Avatar
What was the cause of your stumble?
Charlie
__________
Dredgeguy
Dana 4:10 gears
Polished LT5 by Haibeck
Old 08-09-2023   #8
AlbanyBrian
A new set of plugs solved the misfire problem, even though the old plugs looked ok. Then I had a check engine code for the knock sensor that was intermittent. Once I got rid of the misfire then the knock sensor issue would prevent the engine from pulling to the rev limiter in 4th gear. Check the knock sensor wire from the sensor to the ECU, no issue, so replaced the knock sensor and now the engine will pull to rev limiter in 1st thru 4th gears. Haven?t tried to hit the rev limiter in 5th gear, too fast for the country roads IMO.
Brian
Old 08-10-2023   #9
dredgeguy
dredgeguy's Avatar
Thanks, I have a similar issue we are tracking down. Plugs, wires and injectors were changed at Haibeck 20k miles ago. We think the problem is coils, they are aftermarket and have 65k miles on them. Will pull the plenum and hope to see the problem on a coil.
Charlie
__________
Dredgeguy
Dana 4:10 gears
